Double angles with single bolts.
Do the AISC tables for double-angle columns require a two bolt minimum at each end? I know that the single-angle column design provisions require that, but I thought I'd read that the column tables required this as well. I'm having trouble finding it anywhere and now I question why that would be the case anyway.
