Leakage from Plate and frame exchanger
Hello Friends
We are facing external leakage (gasket) from a plate and frame exchanger. It happens only when the flow rate is increased beyond a certain value.
Exchanger is supplied by Alfa laval.
Request suggestion for possible causes which can result in leakage with increased flow rate.
Shanky
Shanky
RE: Leakage from Plate and frame exchanger
Good luck,
Latexman
To a ChE, the glass is always full - 1/2 air and 1/2 water.
A temporary solution may be increasing the bolt's torque, but be careful, too much torque may damage the bolts and gasket.
I'm termal and mechanical designer of heat exchangers and pressure vessels.
I hope my answer be helpful.
