Pipeline diversion guideline and process
Hi there. Many thanks for your previous replies to my question. I am now involved with a new task and its about pipeline diversion. I need assistance with regards to if there is a/are technical guideline documents out there to aid in this task and if not, if we have experts that can advise on the practical and technical aspects. The pipeline range from water,gas,oil,sewage. My initial questions are as follows:
1- How is it decided that the pipeline has to be diverted.
2- What are the process of determining the diversion location and new tie in points. What has to be considered.
3- Do the answers to the first two questions apply to all pipelines regardless of the product?
Happy to provide further information to aid response.
RE: Pipeline diversion guideline and process
What position are you in?
What type of company?
Do you not have access to anyone in your company to ask?
whilst there are some general guidelines, these are the sorts of services offered by experienced pipeline design consultants who can answer more specific questions for a fee.
These questions though are very vague and general so the answers will be likewise....
What position are you in- Junior Mech design (gas) Engineer with no experience of diversion work.
What type of company- Engineering Consultancy firm based England
Do you not have access to anyone in your company to ask- lets just say am the only one in my department. All my senior personnel resigned when i started so its been a steep learning curve for me.
The task is for proposing options for utilities which will be affected as a result of a major infrastructure project. The proposed infrastructure will either cross an existing pipeline, or will be in a vicinity of an existing pipeline. Initial approach i am doing is to do this exercise and present it to the utilities company. I just need some guidelines and things i need to put into consideration from practical and technical perspective. Hope this sheds more light.
Thank you for your response in advance
Start with PD 8010 pt 1 - there are some very good sections in there.
Diversion - Required if the new infrastructure is going to hit or get close to the existing utility or you can't protect it sufficiently during construction or operation. Most existing services will have rights extending 3m or more from the pipe outer edge.
Diversion location and tie-ins - mainly practical things like access to the sites, land owners, location of other services ( especially overhead wires) and ease of draining or venting the diverted pipe of its contents
Sewage is often a gravity drain on a constant slope so diversion can be really problematic unless it's a "forced main", i.e. pumped.
Many utilities use push fit pipes so may need anchor blocks.
The task of clearing and making safe the line for diversion is the responsibility of the owner, but they can charge a lot of money for this and depending on usage it may be difficult to schedule in.
diversions in the UK need planning permission only if they are under 16km long, so you need to find out from the planning authority if your diversion route is acceptable.
Design wise, replacing like with like is usually OK, but each company will have its own particular requirements and in most cases will do the engineering itself.
With regards to the 2nd to the last line, i imagine this is the diverted section you are referring to with regards to the length?
Yes it's the diverted length. This changed a few years ago, but some people might still remember when it was the total length of line including diversion which used to be the criteria.
The issue is that to get Planning permission you really need to nail down the diversion route before you can apply as there is little to no deviation allowed without needing to get a revised application approved.
Like I said I'll keep it to myself - anywhere all the senior engineers have gone won't inspire confidence in your clients if / when they find out....
I find this a bit alarming.
What do you mean, "the pipeline range from water, gas, oil, sewage"? Be speific, a gas pipeline requires compressors whereas the others will need pumps. Are we talking about gas pipeline looping?
Ganga D. Deka, P. Eng
Canada
Do you have a written project scope of work? You said you are a junior engineer, seniors have left the company. Is it something you are planning to add parallel pipelines in the existing ROW? To do this task, you first need to get hold of their existing drawings and documents, do hydraulics, select pumps/compressors, do a layout for yard piping and tie-ins.
Laying additional pipeline in the existing ROW will need to meet the spacing requirement of the local adjudication regulation.
If there is no space in the existing ROW, you are in bigger trouble. You will need a GIS team for routing selection.
I am not sure, how you alone will handle a project of this scale by yourself. It needs a whole resource team.
Canada
