Flow detector against spot check (UT)
Dear All.
Recently, we carried out UT Spot thickness check on our pipework, the readings obtained were different than the readings obtained by flow detector, all flow detector readings show higher thickness than spot check,
Can some body advise whey such difference >
Thank You
Abdulla
