RCA of overvoltage 132kV line tripping
Hello all,
I am a recent electrical engineering graduate, currently given the role of a power system operations engineer.
We have a 100 MW generation, with two outgoing circuits connected to a 132kV grid. The length of the circuit is 100 km each. During the shutdown of Line-1, at first, breaker at the grid end was first opened. At the generation side, Line-2 tripped on TOV (time delay overvoltage), the disturbance record from relay gives information that phase voltages rose up to 95kV.
I can't figure the reason that led to such high overvoltages since it's a medium transmission line and Ferranti effect is still not that much appreciable.
Another thing is that relay picked at the grid end is 'distance trip- CB close-closing block' and 'carrier received'. How the relay sensed overvoltage as a fault and does overvoltage protection can be used in inter tripping with other relays (like distance tripping in our case)?
Please help me analyze this tripping case, thank you.
RE: RCA of overvoltage 132kV line tripping
