Regarding Refrigeration system
we r using Refregeration fluid 30% glycol and 70 percent water as coolent liquid . Checking if we increase the Glycol water ratio to 40-60 .OR 50-50 GLYCOL WATER ratio. IS t cooling time will reduce .pls suggest. What is plus and minus when we increase the glycol content. Tnanks
RE: Regarding Refrigeration system
