Simple Cylinder with Nozzle Indicating a Zero Design Pressure
In Compress we have a simple cylinder and a single LWN nozzle with user-defined nozzle loads. The output displays a nozzle design pressure of zero. The pressure stresses in the WRC 537 portion of Compress are also equal to zero.
Is anyone aware of a default value that could trigger this?
I tried adding heads on the cylinder to see if that could solve the problem but it did not.
We have Compress 2017 Build 7710.
Thanks.
RE: Simple Cylinder with Nozzle Indicating a Zero Design Pressure
Turns out "full area replacement" was checked by default and there was insufficient reinforcement... nozzle design pressure (or MAWP) was set to zero in the calculations.
