Part 9 Canadian Code Strip Footings
Hello everyone,
I have a basic question regarding strip footing design, particularly for Part 9 structures from the NBCC (mostly residential). From my understanding, Part 9 gives design criteria for unreinforced concrete footings. Is it true that if the footing width and thickness meets the Part 9 requirements you can design these footings without any reinforcement? In my limited experience, I've seen many residential drawing packages with rebar in the strip footings.
Thanks!
Thanks!
RE: Part 9 Canadian Code Strip Footings
BA
