SMC protective coating against UV
I need to aply a PU protective coating on SMC (polyester reinforced with glassfiber) components for outdoor use. This coating is intended to give protection against UV surface degradation and avoid glassfiber blooming. This protection should have, at least, 5 years of warrant (after 5 years the coating can be replaced).
Any one knows what kind of coatings commercial brands are suiatble for this protection?
RE: SMC protective coating against UV
http://www.ppg.com/car_indcoat/powder7.htm
http://www.dupontpowder.com/aromatic.html
http://www.dupontpowder.com/aliphatic.html
http://www.coatingsandcolorants.com/index_flash.phtml
