RFID reader with 2 antennas
Hi everyone,
I need to make an RFID solution with 2 antennas,
Is there a reader in the market that can do this job,
Thanks in advance,
ATarek
RE: RFID reader with 2 antennas
The RFID modules, both in 125 kHz and 13.56 MHz versions, are only a few dollars each. Including their attached or built-in antennas.
It'd be much easier (almost trivial) to use two such modules, and integrate their outputs via a micro-controller.
In other words, "parallel" the modules, not the antennas (where "parallel" is an oversimplification).
I'm sorry if the question is not very clear,
Is there an RFID reader Chip that can operate with 2 antennas,
V1BLL,
Do you know suppliers that can help me develop such modules but with specified dimensions?
Thanks in advance,
ATarek
Developing modules with specific dimensions is essentially a PCB design exercise.
