vibration sensor
vibration sensor
sir i have 4-20ma vibraton sensor and i converted that current op into voltage(0-10v).and i give that op value into iot device advantech wise 4012e.it shows voltage output i want to convert that voltage into velocity(mm/s).give me some therotical equations and formula.my sensor sensitivity is 100mv/g.
RE: vibration sensor
x(t) = A sin ωt
Integrating...
v(t) = ωA cos ωt
a(t) = -ω2A sin ωt
This all is very basic mechanical vibrations. Do you have a mechanical engineer on your site who can help you? Mechanical resonance is not equivalent to resonating RLS circuits. I don't care what they taught you in college.
Do you understand what your gauge actually is reading? I am guessing it is acceleration.
JHG
It sounds like its output may be based on an "overall" reading. If so, the frequency information is lost forever.
TTFN (ta ta for now)
As I read it, the raw signal out is an option with an actual 3rd electrical connection, in addition to a 4-2- mA output.
All the 4-20 mA outputs are a version of "overall" reading.
Peak Velocity (Low Frequency) - 180 to 60k cpm (3 to 1000 Hz)
RMS Velocity - 600 to 60k cpm (10 to 1000 Hz)
RMS Acceleration - 3 to 1000 Hz) / 180 to 300k cpm 180 to 600k cpm (3 to 10k Hz)
Without detailed amplitude vs frequency information ( FFT) before being turned into an overall, I don't think there is much hope of converting acceleration into velocity, etc and etc.
Walt
Oops! Differentiating.
JHG
