PLS Cadd "Generating Allowable Span File" error
Good evening-
I'm new to the pls cadd software. I've taken the training course as my first introduction to the program, so bare with me as I'm trying to learn.
I tried to generate the span files for use in optimum spotting however, I couldn't get the span files because they ended early do to errors. I followed the tech note on optimization and had some success with tangent structures. However, the deadend structure, RUS TS-5G, fails because the usage is at 366% at a wind span of 0. To me this makes no sense because the structure should be able to handle more.
Notes:
I and using structures straight from powline's RUS library.
The conductor is penguin.
I removed load cases that use max wind and cases that have broken conductors.
Any insight would be appreciated!
Notes:
RE: PLS Cadd "Generating Allowable Span File" error
_____________________________________
I have been called "A storehouse of worthless information" many times.
