Aluminum Grating Brace Supporting Members?
Is it common practice to consider aluminum grating attached with screws and saddle clips as bracing the top flange of the supporting framing?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Aluminum Grating Brace Supporting Members?
Often site will completely remove gratings during certain work scopes to improve access below the deck etc., so if you rely on it, it might not even be there.
