import a File to Abaqus that will be used as Beam.
Hello
I design a model in Blender that I wanted to do a stress analysis on it in Abaqus. I exported it to AutoCAD in order to export it again in a SAT file(faces). after doing so I had a problem in Abaqus it was imported as 2000 parts(shell), the Geometry were a bit complex and node number in Mesh were to high. the model is close to a truss structure
I imported the file again to AutoCAD as Lines, now I need to exported it to Abaqus as Beam(wire) and I don't know how and if it's possible.
