Older members not on maintenance notice From Alibre
After Alibre bought back the system from Geomagic some things are happening with the Licensing systems here are a couple of quotes from Alibre sent out to all users of record. •
Important Announcement About
Your Design Software
Dear valued customer,
You are receiving this email because our records indicate you are potentially using a legacy Alibre Design or Geomagic Design product that will be affected by upcoming changes. If you are no longer actively using these versions, please disregard this message.
Affected Products
The products affected by these changes are:
• Alibre Design 14.x and earlier, released prior to February 2014
• All versions of Geomagic Design
Alibre Design up to 14.x and Geomagic Design 15.x
• The legacy licensing server these products use will be decommissioned on June 26, 2018.
• You will be able to continue using the software, but you will be unable to reinstall it.
• Please visit the FAQ below to learn about your options.
Visit FAQ #1 for these specific Geomagic Design 16.x and later
• 3D Systems is terminating access to the legacy Flexera license mechanism on June 26, 2018.
• Geomagic Design 16.x and later will not continue to run.
Visit FAQ #2 for these specific changes
What should I do?
Please visit the FAQ specific to the product you use to learn about why this is happening and what your options are. To determine which product you use, open Alibre/Geomagic Design and go to Home Window > Help > About. Check the Version line.
Best regards,
The Alibre Team
Affected Products
What should I do?
Best regards,
The Alibre Team
You are judged not by what you know, but by what you can do.
