NX 11 custom ribbon bar size
Hi
Is it possible to change the ribbon bar
width. ?
And the icons to be fit relatively
To the bar width.
Thanks in advanced.
width. ?
To the bar width.
Thanks in advanced.
RE: NX 11 custom ribbon bar size
Actually the ribbon bar will adjust to the width of the NX desktop size. Icons o.o.t.b will remain on the same position relative to the right side of your screen.
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX11 / TC11
only.
If my desktop taskbar is in the minimu
width possible. Is that mean that the
ribbonbar width is also is in its
minimum width Possible.
Thank you.
www.nxjournaling.com
Thank you Cowski I clarify my intension.
This is my nx top screen
and this is my ribbon bar
and this is my desktop task bar
all in the x-direction occupied the full screen
and my interest is the width = the y-direction
John R. Baker, P.E. (ret)
EX-Product 'Evangelist'
Irvine, CA
Siemens PLM:
UG/NX Museum:
That being said, if you DO start a new thread, I'll be glad to give you some insight into the purpose and behavior of this function.
Irvine, CA
Siemens PLM:
UG/NX Museum:
Irvine, CA
Siemens PLM:
UG/NX Museum:
of the ribbon height that I'm talk about.
I usually think in length , width for
shape like a rectangular length and rectangular width.
Irvine, CA
Siemens PLM:
UG/NX Museum:
I'll play with icons sizes and see the results.
