stiffness matrix of Pinched cylinder problem
hi
Pinched cylinder problem is a benchmark problem (as shown in attached file), I want to solve it by MITC4+ element which is 4node element and has 5-Dofs per node
to calculate the total stiffness matrix, should i compute the stiffness matrix of each element in local coordinate next transform to global coordinate then assemble it to total stiffness matrix?
RE: stiffness matrix of Pinched cylinder problem
https://welsim.com
