Anchor on Blockwork
Anchor on Blockwork
Anchor on Blockwork
Can someone help to understand how the hilti software compute for the local brick failure(shear). I already tried to search at their manual but i only found tables not the actual computation. Thank you in advance.
RE: Anchor on Blockwork
Hilti (and many other component manufacturers) draw results from empirical testing, not from design calculations.
thank you LO
