Select Cylinder Faces?
I have this bit of code that allows me to select faces of solid bodies. It took me a while to find how to do this on-line. Now I am wondering if I can take it a step further and select only cylinder type faces?
Function SelectFaces(ByVal prompt As String, ByRef selFace As List(Of Face)) As Selection.Response
Dim theUI As UI = UI.GetUI
Dim title As String = "Select Faces"
Dim includeFeatures As Boolean = False
Dim keepHighlighted As Boolean = False
Dim selAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific
Dim scope As Selection.SelectionScope = Selection.SelectionScope.WorkPart
Dim selectionMask_array(0) As Selection.MaskTriple
Dim selObj() As TaggedObject
With selectionMask_array(0)
.Type = UFConstants.UF_solid_type
.Subtype = 0
.SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_ANY_FACE
End With
RE: Select Cylinder Faces?
Instead of UF_UI_SEL_FEATURE_ANY_FACE try using UF_UI_SEL_FEATURE_CYLINDRICAL_FACE.
www.nxjournaling.com
Awesome! Thanks cowski
