Is there a Microstation version of a "Hyperlink"?
We mostly use Bently's Microstation Power Draft 7.1 and I'm looking to see if there is an equivalent to AutoCADs "hyperlink" feature to link you to an internet page.  If anyone has any ideas, feedback would be greatly appreciated.  If PD 7.1 Does not have it available, does the new V8 version?
RE: Is there a Microstation version of a "Hyperlink"?
According to the Powerdraft Help file, the closest that it comes to a hyperlink is found in the File>Associate dialog box. Experiment a bit and see what you come up with.
Robert Weber, EI
Maurer-Stutz, Inc
www.maurerstutzinc.com
"I am satisfied that your answer is correct. I am not, however, satisfied that your answer is right."
Not sure about "Power Draft" but in the full version of MicroStation ... the type in command would be ...
attach webtag
Sorry in advance if my tip doesn't help.
Rich
