Thicker shell or add stiffener?
Let me begin by stating that my query is a hypothetical one and very general in nature; consequently I cannot supply specifics like material specifications and exact dimensions. Who knows, maybe their exists no available general answer or rule-of-thumb. The situation is one in which an economic decision must be made between increasing the thickness of a cylindrical shell or alternatively adding a single exterior stiffening ring to a thinner shell, in both instances to provide additional support and prevent buckling due to a given external pressure. Let's assume that it is allowable for the stiffening ring to be attached by intermittent double fillet welds. Let's further assume all the materials are low-alloy carbon steel and no special PWHT or MDMT conditions are relevant. I'm sure that such an economic analysis would depend on the production volume, i.e. the number of identical shells to be fabricated, or would it? Considerations I suppose would be the cost to purchase, bend, and weld the stiffener verses the additional cost associated with the thicker cylindrical shell? I do not have a clue as to the cost of labor for bending (shell or stiffener) and the material and labor cost to produce welds. I am not lazy; if anyone can direct me to a good resource I am am willing to do the research. Thus far I have no success in that regard. Alas, I am rumbling.
RE: Thicker shell or add stiffener?
What are the penalties for a thicker shell? Weight, cost of material, cost of shipping the heavier weight item, difficulty of rolling the thicker shell - perhaps a few others. If your application was weight-limited (aerospace, airplanes, extremely expensive material) then that might matter.
But, most fabricators rolling pressure vessels can roll just about any reasonably thick material, so the cost of the material is likely less than the cost of welding and certifying the outside rib or ribs. Ribs add weight and material as well. Ain't no free lunch anywhere but politics. And even there, it is the lawyers and lobbyists who get the free lunch, and the taxpayers who pay.
If your welding cost per man-hour is very low (China fab) then the material cost could be acceptable.
If the shell is not "too long" or the thickness increase is not "too great" then thicken the shell. If nozzle reinforcing, nozzle loading, or perhaps other structural considerations such as Zick can benefit, thicken the shell.
If not, add a ring. If the design is well advanced such that thickening the shell causes one to practically start the design over, add a ring. *
Rings can usually be burned in segments from plate, such that the cost of the ring itself is not too great.
If serial production is involved, that may favor a thicker shell, as the long seam and round seam welding are (presumably) semi-automatic processes whereas the attachment of the ring is not.
I suspect a given shops' "culture" will have an influence as well.
Look forward to others' input also.
Mike
* On Edit: Hate to say, but I've done this more than a few times :)
Have you tried doing a couple of designs, doing the analysis and getting quotes on it?
Are you constrained by engineering costs, fabrication costs, or weight?
JHG
"Everyone is entitled to their own opinions, but they are not entitled to their own facts."
