Preserving Roadway Benchmark Help
Sorry guys if this is a repost. I posted this in the survey section also but thought it may be more appropriate here.
Most counties I believe have a standard spec or procedure on how the Contractor should preserve, protect, or replace a survey monument in case it is disturbed or damaged during repaving procedures. Typical street monuments are embedded into the ground 3+' so it will be difficult to disturb the actual location of the pin. What about mag nails or "y" cuts on the roadway surface. We are repaving a roadway and some of the bench marks are in the form of mag nails and "y" cuts that are going to be disturbed. Not sure why an actual street monument was not installed for these areas. Thanks for your help!
RE: Preserving Roadway Benchmark Help
