NXopen Datum plane on Curve
Got a challenge maybe someone can help me out.
How to create a datum plane on a point, normal to a curve and with the orientation to curve parallel to X axis.
Using a recorded journal is not an option, is just way to much information and I can sort through it and make it work.
basically I need to measure the angle at on a curve at specific points to the XY axis, I think creating a datum plane is the best option, but maybe someone has a better ideia.
