Chemical Treatement
Chemical Treatement
Chemical Treatement
Dear All.
What are the factors controlling the selection of using oil or water soluble corrosion inhibitors for trunk lines.
Thanks every body
Abdulla
RE: Chemical Treatement
Would not it depend upon what fluid is being pumped or sitting static in said trunk lines?
If oil-based, I suspect you would want oil soluble corrosion inhibitor, as water may be forbidden in the line.
