Cohesive Elements in Abaqus Implicit and Explicit
Hello Everyone,
I have recently seen a very strange and interesting challenge through my Abaqus simulation might be exciting for more investigations. We want to model a composite material defamation with Continuum Elements (C3D8R) and Cohesive Element (COH3D8). We have to also implement a pre-tension load in the model based on the practical case.
The problem is following:
Through two simulations with the same model and same material; if you implement a pretensile load on Cohesive Elements:
1- In Abaqus Implicit: the all Cohesive Elements reach all together to the damage initiation point; MAXSCRT=1 (the starting of degradation) just after the first increment
But for:
2- In Abaqus Explicit it works fine and Cohesive Elements reach to this point after a valid number of increments.
For both cases, I have used exactly the same model.
In this case, I would be happy if somebody could let me know if has any relevant experiences or hints.
Thanks in advance,
Best regards
RE: Cohesive Elements in Abaqus Implicit and Explicit
The acoustic impedance mismatch can have a significant influence in a dynamic, especially an Abaqus/Explicit, job. So, if there is any discontinuity in terms of material properties or mesh, then that can result in reflections, which can have further downstream consequences.
Are you new to this forum? If so, please read these FAQs:
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
