Welding of dissimilar metals
Hi all.
We need to weld 16 gauge SS plate with 6mm CS plate. We are using TIG welding process with SS 309L as filler rod. Problem is that the SS material is getting melted during welding and the filler material is not at all getting deposited on SS. Kindly share your thoughts and give some suggestions to weld this SS material with carbon steel.
Thanks.
Thanks.
RE: Welding of dissimilar metals
You need to be applying most of the heat to the thicker material.
And your heat input look to be too high.
B.E.
You are judged not by what you know, but by what you can do.
No point discussing proper welding technique here. Welding 1.5 mm to 6 mm isn't easy, but still in the "doable" range.
http://be.linkedin.com/in/fusionpoint
