Reduced integration
Reduced integration
Reduced integration
How the stresses are recovered to nodes from reduced integration?
Element quad4, one gauss point in the center of element.
RE: Reduced integration
They're extrapolated according to the element shape function and then averaged to give a single value.
The same procedure is used for fully-integrated elements
Dave442 I agree for the stress recovery for 4 Gauss point.
But I can not imagine inter/extrapolation from one Gauss point.
Is is not that the stresses at nodes of element are the same as stress at one/centre Gauss point?
For an element with one integration point the stresses at the nodes and integration points are the same.
These elements are sometimes called constant stress/strain elements.
Nodal values may still get averaged to produce a single value though.
Thank you
