API-12F no anchor bolt needed for tank?
I'm doing the foundation for a small tank, height is 7', diameter is 4".
I noticed there is no bolt center diameter for my anchor bolt.
The base plate O.D. is just 1/2" wider than the tank 0.D. so nowhere to put a bolt anywhere.
I called the vendor and was transferred to a supervisor and was told based on API-12F it does not need anchor bolts.
Is this supervisor correct?
I don't know anything about API-12F.
What if this tank is located in hurricane zone and/or elevated structure where wind is significant to overturn or slide this tank?
RE: API-12F no anchor bolt needed for tank?
If necessary, weld anchoring clips onto the tank. The tank should have an electrical grounding connection as well.
