High voltage AC withstand testing breakers and SG. What is phase to ground capacitance?
Age old question: sizing the AC hipot. What is the capacitance from ph. to grd. and ph. to ph. of typical breakers from 5kV - 150 kVac? I don't find this information easily from the CB vendors. I know most of them but not all and not the newer rated apparatus and the HV models. Does anyone have a chart of the typical capacitances to calculate the current required to perform the withstand test. Right now I need it for a 66 kV SF6 breaker. To test one breaker is easy but when testing multiple units, it's helpful to know.
Thank you.
Thank you.
