Sprinkler ordinary temperature selection criteria
What would be the choice criteria between the two temperature ratings that manufacturers have for ordinary temperature (135 or 155 ºF)?
Ambient temperatures are normal. Datasheet also specifies the same máximum ambient temperature for both (100ºF).
thanks
RE: Sprinkler ordinary temperature selection criteria
Whichever one is cheaper / easier to get. Probably going to be the 155 degree every time.
Thanks both for the help.
Good point Travis. I checked that with the Victaulic sidewall EC and it appears only listed by UL for 135ºF.
I don’t know.
If your lines are at say 20 feet and you pipe down for the valve,,
Will you really get air out??
Think you're on the wrong thread cdafd :) Will respond on the other one.
