Torsional elastic modulus
Could anyone give me the fomula for finding the torsional elastic modulus of a rectangular bar. Thanks
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Torsional elastic modulus
J=k*b*t^3
where:
b = width of section
t = thickness of section
k = constant depending on b/t ratio, as follows:
b/t k
1 0.141
1.2 0.166
1.5 0.196
2 0.229
2.5 0.249
3 0.263
4 0.281
5 0.291
infinity 0.333
prex
motori@xcalcs.com
http://www.xcalcs.com
Online tools for structural design
Anthony Tugwell
Project Director & Consulting Engineer - just relocated to Australia
The exact text extract is "The value of torsional elastic modulus (G) may be taken as 28.3 GPa for glass fins"
The shear modulus is used in computing torsional deformation
(twist) of a member.
G = E / 2 / (1 + mu)
E = young's modulus
mu = Poisson's ratio.
Check any book on structural mechanics for the relationships
between torsional moment, torsional constant, G and twist.
Hariharan
Modulus of elasticity, G, also known as Modulus of Rigidity.
G= fV/Y
fv= torsional shearing stress(Pa)
Y= gamma, strain in the material
If u r designing glass than 28.3 GPa is correct, upto 30 is fine.
I would suggest u use the G values directly rather than compute from first principles.
Riz
If u use formula given by Hariharan than the parameters are as follows:
E = 70KPa
mu= 0.22
Thus G = 28.7GPa
Riz
E = 70KPa
mu= 0.22 ( for stress parallel to grain )
Thus G = 28.7GPa
Riz
Anthony Tugwell
