2017 ASME Viii Div 1 Appendix 1-10 removed now use Div 2, but which allowable?
Hi All,
Since appendix 1-10 has now been removed from the 2107 edition of the Div code, we now go to use Div 2 part 4.5 for larger nozzles (ratio greater then 0.7 to 1). Which material allowable stress shall we use now , Div 1? Div 2? Vessel design code is Div 1.
Thank you
Thank you
RE: 2017 ASME Viii Div 1 Appendix 1-10 removed now use Div 2, but which allowable?
