Need a name of nx11 custom folder for sheet metal application
Hi
1
I Need the name of nx11 custom folder for sheet metal application (UG_ ...)
for example UG_APP_MODELING is for modeling application.
And if someone know were I can find a resrevoir of icons tha fit to NX11
or a free application to build them.
Thank you in advanced.
1
RE: Need a name of nx11 custom folder for sheet metal application
I create my own 112x112 icons in either Paint or GIMP. To make the background transparent set the colour to R255 G0 B255.
Mike Hyde
www.astonmartin.com
NX12.0.0 with TC11.3 and Vis 11.3
That is
I'm not much good with MS Paint or GIMP (both good tools), so when I need an icon I'll usually google "royalty free icon" or "royalty free vector graphics". With some patience, an icon that's "close enough" can usually be found. When the off-the-shelf icons don't cut it, I turn to Inkscape, a free vector graphic editor. With it I can cobble together an image from other royalty free graphics. For instance, in the icon below, I removed the pencil and paper clip from a clipboard graphic, added and resized a camera graphic, then exported it out to a .png file for the button icon.
www.nxjournaling.com
