Title block table problem
Hello I just create a new title block.
And I have a problem with a number attribute.
It always shows six digits after the comma.
If I use the same text outside of a table it just show the necessary digits.
I also tried the style settings of the table but that does not influence shown attributes (only numbers).
I also uploaded an example part to show my problem.
I used NX8.5 but I have the same problem in NX11.
Klaus
Klaus
Unigraphics NX Key user
it all started with V13
RE: Title block table problem
You could add another column and hide the line in between the cells and add the [kg] in that extra column.
or you can link to an expression and control the decimal places that way.
Uploaded is a video showing how to do the second suggestion.
Anthony Galante
Senior Support Engineer
NX3 to NX11 with almost every MR (24versions)
Thanks for the Info.
I will split the column.
This will be the easiest solution without additional attributes.
