Volume Expansivity
Volume Expansivity
Volume Expansivity
I have an oilfield problem where I have trapped pressure between two concentric strings - the fluid is diesel. I need to calculate the pressure increase due to a 20 deg C increase in temperature.
I'm a bit rusty on equations of state and other thermodynamic principles but it should be easy for the expert.
Pressure of 200 psi trapped in 5000 ft of 9 5/8'' x 13 3/8'' annular space. Original temperature is 20 deg C. This temperature is increased to 40 deg C without any bleed off facility. Ignoring the deformation effects on the steel casing what is the pressure increase? I assume you use volume expansivity & isothermal compressivity coeffcients though cannot find values.  Thats as far as I got!
kpj
RE: Volume Expansivity
Look in the FAQ section. I have posted one on the (frequently re-occuring) question.
Best Regards
Morten
I've been looking through texts all week for this explaination (without getting into partial differentials).
Thanks for the pointer - I'll go home from work tonight a happy man.
