Nx11 icons text issue
Hi
Is it possible to remove icons text quickly
or as possible quickly.
From all icons.
Thank you in advanced.
From all icons.
RE: Nx11 icons text issue
Best guess would be to arrange for this in the ribbon tool bar files. There you can define how an icon is show.
As an example
CODE --> file
Will show only small Icon
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX11 / TC11
I'll try it by toolbars one by one.
Before I'll do that.
Is that will give me more space
in the graphics window.
Thanks again.
It is also depending on which role you are using..The Advanced role already gives you an improvement on ribbon size (compared to the other roles)
NX9 / TC10.1.2
