Need Help Modifying A Trim Body
Greetings:
I have a trim body (pic attached) created from a part model. There are (6) sets of (2) holes ((12) total) around the circumference that I need to get rid of and blend that area with the (3) surfaces coming together right there so that I have a solid trim body in that area. I cannot figure out how to get rid of the small holes. Can anyone assist me?
Thanks in advance,
Brent
Thanks in advance,
Brent
RE: Need Help Modifying A Trim Body
www.nxjournaling.com
Is there no model history to this part or something (AKA a dumb model)? If that's the case, have you tried Delete Edge and selecting all of the edges around each hole? If that doesn't work, you may have to Extract each face, Untrim them then Trim Sheet to the hole edges and Sew or Patch into the model. Not saying either method will work flawlessly, but without the model, it's anyone's best guess.
Fill Surface was made just for these situations but it can take a bit of practice to use it effectively.
I'm sure more users might have other ideas.
Tim Flater
NX Designer
NX 11.0.1.11 MP4
Win7 Enterprise x64 SP1
Intel Core i7 2.5GHz 16GB RAM
4GB NVIDIA Quadro K3100M
Thanks again,
Brent
