road estimate
road estimate
road estimate
I am not a civil engineer and need some help in cost.
Is there any way we can estimate the 24' wide street with 24" dia. culvert pipe/mile?
Appreciate any help.
RE: road estimate
Not sure what you mean by estimate. Are you referring to cost to construct, design or size a culvert?
RE: road estimate
I suggest asking your community, county. etc. public works department for a rough cost by some unit that is convenient for them for street about as much traffic as you plan. If you happen to be one of them, next bet is a local road building contractor. Let them know you may want to negotiate a job sometime. Heavy traffic takes thicker pavement than a less used street. For any job like this you need plans and a detailed contract. That's where the CE comes in.
RE: road estimate
Sorry,
It is cost estimate to construct.
RE: road estimate
The new street/road connects to existing road and will be about less than mile long. has drain in the middle so need pipe culvert for drainage
RE: road estimate
If you have a listing of Quantities you can use a source like RS Means for your area. The link below is another source for major construction activities. Hope these help.
http://www.get-a-quote.net/QuoteEngine/costbook.as...
RE: road estimate
Thank you
RE: road estimate
I guess that you are not working for a general contractor otherwise GC involved in this type of work can estimate such cost. Cost per miles not only depends on product cost but also on excavation including blasting if necessary and dewatering, refill, manpower, equipment usage, purchase of project plans, insurance, bidding, and possibly potential delays such as interruptions from OSHA, jurisdiction and insurance engineers and potential accidents.
