Questions about screw piles
Two questions about helical piles:
1. How accepted is the Torque Correlation method for designing helical piles?
2. For frost heave, is getting below the frost line enough for a screw pile or should you also check the uplift force due to adfreezing. One geotech report I saw recommended using 100 kPa over the surface area of the pipe in the frost depth to get the uplift force.
RE: Questions about screw piles
2. I would think that uplift forces will came from forces acting at the bottom of the pile cap. But better to check with your geotech.
Dik
