How to launch PTS with a program in NX11 ?
Maybe a question for Taylor Anderson
How to launch PTS with a programm in NX11 ?
I have design a complex modl assembly with PTS and I need to open it by program to automate all my process.
It seems that PTS in an old function (before NX4) and there is no code available
Or maybe with unfunc ?
Any idea ?
Thanks in advance
Any idea ?
Thanks in advance
Didier Psaltopoulos
http://www.psi-cad.fr
RE: How to launch PTS with a program in NX11 ?
The only difference is, compared to earlier versions, that PTS is now directly integrated in NX11 and no longer a stand alone application.
How to control (start) this through coding I cannot help you with unfortunately. I don't know if it is already supported by Journal but you could give that a go. At least you can see then how it would look in code.
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX11 / TC11
