in an oil well, What is a test line for?
Hi
I am auditing flow lines of new oil wells. Oil wells have a regular oil pipeline and a test pipeline.
What is the test pipeline for?
Carlos Molina
Carlos F Molina
RE: in an oil well, What is a test line for?
Err testing the well?
I don't understand your system so you need to draw it. Normally a single well will simply either have test connections for a mobile test separator or 3 phase meter or will connect at a manifold with other wells to a test header so that individual wells can be tested.
But there might be a different type of test. Please elaborate.
Hi
The testing is to see if it produces.
Thanks.
Carlos F Molina
Kind of. Oil fields typically sell oil by the lease. The allocation back to the wells (for engineering analysis) is based on periodic well tests. You shift a well to test, assign a flow rate and assume that this flow rate remains constant (or at least a constant proportion of the total field) until the next test.
David Simpson, PE
MuleShoe Engineering
In questions of science, the authority of a thousand is not worth the humble reasoning of a single individual. Galileo Galilei, Italian Physicist
