2400 x 1600 mm door in shell of the tank
Hello all,
Again I am having another issue with the construction of an ''API 650 tank'' with dimensions 10.5m diameter x 9.6m heigth, I was checking the design drawings for the construction and I found this kind of opening, like a square door of 2400x1600mm.
the design of door present reinforcement and an over compensation in the thickness of the shell where this opening is placed(see attached drawing).
Have you seen this kind of opening in another codes of standards, or API talk about this kind of door?
thanks in advance
thanks in advance
RE: 2400 x 1600 mm door in shell of the tank
Larger openings can be built, but the tank is no longer an API-650 tank, and you're on your own for design and detailing of the door.
