NX 11 general pocket
Hello at all,
what happend to the command "General Pocket". I can´t find it in NX11.
Best regards
Best regards
RE: NX 11 general pocket
www.nxjournaling.com
They do approximately the same, the Emboss is more modern, with preview as soon as you have entered necessary input.
Tomas
Tomas
Thank you for your reply! Emboss is so modern that it isn´t working (at least not for me, maybe the problem sits in front of the computer).
To specify this, i do not want make a swept volume on a cylindrical shape. This feature is perpendicular to the surface. I want to sverve round the cylinder in a kind of pocket shape. A picture is attached for better understanding.
This used to work with general pocket. Why did they remove this powerful tool and replace it with nothing? I solved it now with free form features, but this is so much more time consuming.
Thank you and best regards
Edit (file upload)
You illustration is missing.
If you can upload an example part, ( create a illustration from scratch, not the production part.)
we can try accomplish the same using the Emboss feature.
Tomas
Tomas
