CAD CAM FOR SHOP USE
Hello all,
Thanks for entering my thread.
We are looking for a low cost cad/cam software for shop use. The software features we need, drafting, 3D machining, translators for .stp. .igs, parasolid. If possible, the ability to work with native Unigraphics and Catia files. It will also have to be ITAR compliant.
Thanks for your help,
Randy
Randy
RE: CAD CAM FOR SHOP USE
TygerDawg
Blue Technik LLC
Virtuoso Robotics Engineering
www.bluetechnik.com
ITAR compliant is up to your installation.
Ben Loosli
Working between models can be a pain at times but is getting easier. Solidworks and Catia are the same native format, so that resolves some issues for you. Both Solidworks and Creo also will kinda-sorta open native NX among other native formats. My understanding is that when you hit the "open" button they convert those other formats to parasolids then convert parasolids to their own native formats so you end up with a model slightly better than a step or iges but still lacking constraints and most feature definition. Regardless, you're still going to occasionally be "fixing" others' models to some extent.
