Creating text on face from X, Y, Z coordinates [NX 8.5 Journal]
Is it possible to place text in curve on a face that shows curse coordinate system ?
I create ~ 100 text in curve to the surface and I am trying a journal which will do the things in following sequence.
1. Find a x,y,z by show infomation of the curve( line, splile…)
2. Chose the x,y,z coordinate has round, in my case is X 2500
3. Create text placement in face and curve
4. And done
i use nx 8.5
Can you help me ? thank you
4. And done
i use nx 8.5
RE: Creating text on face from X, Y, Z coordinates [NX 8.5 Journal]
CODE -->
Option Strict Off Imports System Imports NXOpen Imports NXOpen.UF Imports NXOpen.Assemblies Module Intersect1 Sub Main() Dim theSession As Session = Session.GetSession() Dim workPart As Part = theSession.Parts.Work Dim lw As ListingWindow = theSession.ListingWindow Dim ufs As UFSession = UFSession.GetUFSession() lw.Open() Dim myVectors(-1) As TaggedObject If SelectVectors("Select Vectors", myVectors) = Selection.Response.Cancel Then Return End If Dim mybody As Body = Nothing Dim mystartpoint(2) As Double Dim myintersectpoint(2) As Double Dim myfaceparms(1) As Double Dim intersectdata1 As NXOpen.UF.UFCurve.IntersectInfo = Nothing Dim intersectfound1 As Integer = Nothing For Each tempVector As Line In myVectors lw.WriteLine("X "+tempVector.StartPoint.X.ToString) lw.WriteLine("Y "+tempVector.StartPoint.Y.ToString) lw.WriteLine("Z "+tempVector.StartPoint.Z.ToString) Next End Sub Function SelectVectors(ByVal prompt As String, ByRef selObj() As TaggedObject) As Selection.Response Dim theUI As UI = UI.GetUI Dim title As String = "Select Vectors" Dim includeFeatures As Boolean = False Dim keepHighlighted As Boolean = False Dim selAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific Dim scope As Selection.SelectionScope = Selection.SelectionScope.AnyInAssembly Dim selectionMask_array(0) As Selection.MaskTriple With selectionMask_array(0) .Type = UFConstants.UF_line_type .Subtype = 0 End With Dim resp As Selection.Response = theUI.SelectionManager.SelectTaggedObjects(prompt, _ title, scope, selAction, _ includeFeatures, keepHighlighted, selectionMask_array, _ selObj) If resp = Selection.Response.Ok Then Return Selection.Response.Ok Else Return Selection.Response.Cancel End If End Function Public Function GetUnloadOption(ByVal dummy As String) As Integer 'Unloads the image when the NX session terminates GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination End Function End ModuleRE: Creating text on face from X, Y, Z coordinates [NX 8.5 Journal]
