Non-structural Component Seismic Design
I am designing a concrete wall 11' h x 9'-4'' l . The wall is comprised of architectural concrete blocks which has a specific pattern on the face of it. Each block is only 17 lbs. The seismic force acting on the wall is 700 lbs based on ASCE 7-10 13.3. I am planning to support the wall laterally by using HSS 4x2x1/4 @ 3' O.C along the wall. My main concern is how to achieve stability of the blocks since I can not reinforce the wall because of architectural reasons. I was wondering how I can achieve it without using rebars. I would really appreciate if I can get a response.
Thank you,
Thank you,
RE: Non-structural Component Seismic Design
Each block is 4"d x11"w x 16" h
