ETABS load transfer from vertical shell to frames
Hello, everybody. I am wondering is it by any chance possible to transfer area load from vertical shell element to line load on frames? I know that this is possible for horizontal shells, say, if you assign a 1-way membrane, which will transfer the loads onto the adjoining beams, but I am encountering difficulties when applying the same (or similar) procedure for vertical shells and columns. Thanks in advance.
RE: ETABS load transfer from vertical shell to frames
Jason McKee
proud R&D Manager of
Cross Section Analysis & Design
Software for the structural design of cross sections
Moment Curvature Analysis
Interaction Diagrams
Reinforcement Design etc.
