Welded Wire Fabric Designation Help
I'm working on a bridge rehabilitation and have the existing rehabilitation plans dated 1973. In the parapet, the original designer used "33-55 Welded Wire Fabric". We are only replacing a small chunk of the parapet and the DOT has requested we use the same W.W.F. as originally specified. I cannot seem to locate this designation (33-55) in any documentation I can dig up. Might someone have some guidance on this WWF and the equivalent in today's designation?
Thanks in advance!
RE: Welded Wire Fabric Designation Help
Here's a table from the 1971 Edition of Gaylord and Gaylord, "Structural Engineering Handbook" But they only have 33-88 WWF, with 3 inch spacing each way and #8 gage wires. But I think if you put in #5 gage wires (.207 inch diameter) at 3 inch spacing, you'll be pretty close. It looks like the current designation would be 3 x 3 W3.5 x W3.5.
It's one thing to specify it, another to actually get it. Unless you have a whole lot of WWF, it's hard to get the suppliers interested in an odd size (and they're all odd sizes), so get ready to be imaginative.
have you looked at the Wire Reinforcement Institute's TF 101-R-14: Historical Data on Wire, Triangular Wire Fabric/ Mesh and Welded Wire Concrete Reinforcement http://wri.support/TF101-R-14.pdf
Agreed, I'd bet money it's calling out wire gauge. Our manholes are reinforced with plain wire that the shop guys call "six six - ten ten" wire. Likely written out 66-1010.
It's 10 gauge wire in a 6" x 6" grid. Written out in modern WWR designations it would be 6"x6" W1.4/W1.4.
As Jed said it's likely going to be costly to get a small order of a specific wire. I'd ask the welded wire supplier for any scraps of equivalent WWR and see if the DOT is okay with some extra reinforcement. Alternatively making a cage out of #3 grade 60 rebar will likely be more than equivalent.
Professional Engineer (ME, NH, MA) Structural Engineer (IL)
American Concrete Industries
https://www.facebook.com/AmericanConcrete/
wannaabeSE, I tried that web site yesterday and this morning. I am blocked. The site is (erroneously?) listed as a gambling site. My IT guy has been looking into it. I assume that you are able to access the site?
www.PeirceEngineering.com
Agreed that it is 5 gauge wire at 3" spacing each way. I was not able to find an equivalent to that produced today. I like the idea of just using #3 bars considering it has to be epoxy coated also. Or just use a "stock" piece of WWF with a spacing not to exceed 6" and an equivalent area of steel. Many options.
Thanks for the help and the great links. You guys helped a bunch.
