Ansys result files for Fe Safe
Hello Everybody
I would like to know, if i am supposed to conduct a multi axial fatigue analysis using Ansys (with 6 load cases) to be exported to Fe safe , which files should I save ano how can I agglomerate all the 6 load cases results in one output file ? cause in another software it was possible to have all those results in one file and when you drop them in Fe Safe, you got all the 6 databases separately
