Kinetsync Controllers
Has anyone ever experienced a Kinetsync cycling between 10 and 60v when it is supposed to be at 90v and not latching in a synchronous motor?
RE: Kinetsync Controllers
Our amusing problem was DC voltage on rotor before start without input voltage on two impulse cards TRIG 3 .
we found that the voltage from the secondary transformers somehow over the thyristor and orthocopters is the cause of the problem with opening of the bridge and voltage before start that we temporarily solved by removing wires from cathode and gates at one thyristor .
we changed the thyristor but the failure or the malfunction was pointing to the other so our regulator is currently working with 5 thyristors in the bridge because the production was endangered.
Somewhere on the Internet we found the procedure for calibration and adjustment of 2 pulses cards . I suggest you do calibration because there may be a problem here somewhere. In addition, you are supposed to check the voltage on the secondary transformer and the fuse state .
Good luck
Is kinetsync just a piece of junk? I don't know much about the quality or the company. I'm thinking this was just the cheapest option. We have an antique Ideal motor. The company has been through about 3 or 4 ownership changes over the years. I assume it still exists, but I wonder what the OEM recommends to use? I bet it isn't Kinetsync.
